extrusion of a polyline.. .
  • Thread starter Thread starter Delysid
Delysid
only happens to me that from a while (presumably from the last sr) extruding a polyline comes a single surface and not a polysurface? extruding a rectangle as in the example what comes from it is a single surface... as you can see the rectangle selected in yellow and the red supericie that is not exploding. Actually, it should be 4 super planes together. to have this I must first explode the rectangle and extrude the individual surfaces and then reunite them:confused:
strange behavior.. here from me everything normal, both with rhino 4 (last rel of 9 March 2011) and with rhino 5 (last rel of 11 July 2012)
win 7 64 bit
That's why nobody was talking about it. because it only happens to me. In addition to my modest experience, it has geometrically little meaning. the funny thing is that the edge is just a edge but if I go to make a fitting obviously I must first cut the surface.
Thank you mariuss.r, we hope you'll pass someone who's caught before me.
In addition, if extruded closing, artifacts are visible. . .
Another funny clue is that it is a grade 1 surface and diagnostics does not reveal any abnormal object.
something similar happened to me after triggering a plug-in (I don't remember which one).
after countless attempts I solved reinstalling rhino.
I have done several tests for extrusion and everything works regularly from me (rhino 4).
