paulpaul
Vedil motor turns as "result" of dynamic balance between drive torque and strong torque: they increase when you have a positive difference between the first and second. the variable "independent" we say is the so-called "load", indicative of the couple that is releasing the motor and tied to the command organ (% butterfly opening in an eight motor - amount of injected in a diesel).Wait. I think the speech is quite complicated:biggrin:
Can you first tell me if what I write now is correct?
We consider an aspirated engine that works at a number of laps and which is delivering some power. if you want to increase the power provided by the engine, you need to do two things:
1) increase the amount of fuel entered in the combustion chamber;
2) increase the amount of air entered in the combustion chamber (in order to reach the stechiometric ratio).
in an injection gasoline engine, these two needs are met simply as follows: the accelerator, connected to the butterfly valve, provides to increase the air flow in the cylinder and simultaneously an electronic control unit orders the injector to spray more gasoline. Moreover, as a result of all this the engine turns increase.
Are they here?
Thank you so much!! ! ! ! !
you may have high turns and low loads, such as when you accelerate vacuum, motor tending to pack: Minimum resistant couples, at the limit only the internal frictions, and therefore low loads necessary to accelerate the motor, forces on the predominantly inertial manovellism.
high loads and low turns, as when you want to resume from low turns to long marches maybe uphill (high "road load") accelerator pressed, high thermal load, forces on the manovellism mainly due to gases.
so it is not said that if you press the accelerator more the motor accelerates! depends on the dynamic balance of the same! :smile:
