I'll give you a point and see if it's your case, "check size and factor k bla bla bla...":wink:View attachment DIAFRAMMA1.rarI didn't realize this detail... and can I take the dishes upstairs?
Of course, but did you see my file? did you try to activate the flat repetition?Can I make some cuts? to remove them?
when opening the file gives me this error
with swx 2012 sp.3 and 4 I have no problem, I try to attach it created with the version sp.4.View attachment DIAFRAMMA1A.rarche sp. hai su solidworks 2012?
here is this fact with swx 2012 sp.0 see if you can open it.View attachment DIAFRAMMA_2.rarI have sp 0, but can you explain what you did?
It's easy enough to get, see the attached mini-video.View attachment sviluppo_corpo_importato.rarhere is this fact with swx 2012 sp.0 see if you can open it.View attachment 28537
of nothing...:finger:Thank you so much eboss...
And why the hell are you still at the sp0?I have sp 0, but can you explain what you did?
