systematic crash gallery appearance
  • Thread starter Thread starter calacc
calacc
Hello everyone, I have a problem quite simple.
if with creo parametric 1.0 m030 I just venture to touch the gallery button aspect of the menu make the system crashes systematically... I just tried to upgrade to m040 and it does the same. That's a good thing. that depends on the drivers of the graphics card or some parameter of the config pro this I do not know, but I remember that with the m020 this did not happen.
Does it happen to you? what can depend on?
problem due to the existence of old .map files that you would delete if you find them.
Okay, and where could I find these files.maps? how are they generated?
.map files were pre-wildfire appearance files.
probably you will have it in the boot folder of proes, look there, if you don't find it looking on the whole computer *.map.
you will have to delete it and do it again with your current version of creo.
Nice! I am now on vacation, I will try to follow the vs tips and of course I will let you know
Yes, it was so! there were 2 files called "color.map" in the boot directory, deleted those did not happen anymore, thanks endless
