emmora
Good morning to all, in autocad 2008 I am trying to automate the compilation of attributes at the time when I insert a block in the drawing. in practice each block has various attributes that can be compiled manually. I would like to make sure you can choose a record from an access or excel database and automatically connect the contents of the fields into the attributes of the block without having to type them. I managed to connect the db, display the table, but I do not find the solution to carry out the described passage. Thank you for giving me some indication.
