solokite
save,sw allows to insert + parts together (fixed at the origin) without selecting one to one?
Thank you very much
Thank you very much
no, you must select or drag a file to the window at a time.save,sw allows to insert + parts together (fixed at the origin) without selecting one to one?
Thank you very much
Thanks for listening! !I think we can.
if you select a defined number of files to explore resources and drag them into the axieme by placing the mouse cursor over the origin of the axieme each imported part will have the origin coinciding with the origin of the axieme and will be fixed.
I just tried and I (sdw2010) works just like that.
marcof responded with two lines saying that you can't do it... and if we go to gardare well, he is perfectly right:I think we can.
That's absolutely true. I missed it.in truth the kakisan extractor gets the desired purpose; only did not specify that you have to place on the origin of the work plan and not on that of the feature manager.
by curiosity I tried his suggestion and actually the parts were placed and blocked on the origin.
Bye to all,in truth the kakisan extractor gets the desired purpose; only did not specify that you have to place on the origin of the work plan and not on that of the feature manager.
see me that always learns something new:finger:.That's absolutely true. I missed it.
I never had to use this mechanism.
Good. :smile:
Do you see old grumpy slippers?!?! If you shut the steam up and take off the plugs from your ears, from below, we can better "interloquire" and let you know what the world works!see me that always learns something new:finger:.
never needed to do it but good to know. I tried by randomly releasing on the screen without touching the origin... :redface:
The thing is you sleep up. sleep so much that I, at the maximum speed allowed to all steam of 15 km/h, do in time to pass over before you notice. later, if you squeeze advice and help from under the front roller, maybe while I'm spreading coal in the boiler, I can't hear you. :tongue:Do you see old grumpy slippers?!?! If you shut the steam up and take off the plugs from your ears, from below, we can better "interloquire" and let you know what the world works!
:biggrin:
thanks 1000 super helpful...compliments to the online guide! !Bye to all,
Sorry for lack of precision.
but for me the origin is that visible on the screen and not that on the tree.
that I only use it to bind fixed after I entered the first part in the wrong place...:smile:
yellow
you must have some geometric entity in one of the parts far from the origin. just a point in a sketch that ended up sbnaglio at the god's house to cause these inconveniences.it seemed all beautiful, in 3 barrels load 40 composing from 2 mb each.. in a blow had put to crythe problem is that when I zoom optimized it shoots me on mars and controlling parts around there are not.. how do I discover the hippo. .
help, already I miss a couple of degrees,discuss the comparison but with simple autocaddin did not make a nice ctrl+a were selecting the points belonging to the hidden layer and I erased the whole...you must have some geometric entity in one of the parts far from the origin. just a point in a sketch that ended up sbnaglio at the god's house to cause these inconveniences.
you can start checking the individual parts with the display of the snaps activated and find the one that with optimized zoom creates the problem. then pull on the history tree to the first feature, optimize the zoom, reactivate the second feature, optimize etc until 2when you do not find the one that generates the inconvenience.
to me it happened once in a rather big set and I took two hours two to find that fucking sketch that messed up the zoom:redface:
Bye to all,The thing is you sleep up. sleep so much that I, at the maximum speed allowed to all steam of 15 km/h, do in time to pass over before you notice. later, if you squeeze advice and help from under the front roller, maybe while I'm spreading coal in the boiler, I can't hear you. :tongue:
