interrupted object section with real shares
  • Thread starter Thread starter lioid
lioid
Good evening to all, I am drowning in a glass of water and I ask your help.
design many sections of long objects whose central part does not need to be represented as equal throughout its length, for this reason
I have always designed the items really broken, having to pay attention during the quotation by manually inserting the quotas.
exists the possibility of drawing the object in a real way and establishing a portion of the central part to "export"?
clearly in the phase of quotation the program must also measure the hidden portion.
use autocad 2010.
thank you for your help
p.s. I searched both in the forum, and on google but found nothing on such a function.
in the layout environment, I hope you insert the square and views, create two windows containing the affected areas. the broken line of interruption obviously you will put it in the layout environment; instead in the model environment you will move the quota so that it is visible in one of the windows. remember to underline the quota
Thanks for the answer, it is one of the procedures I still use.
in the first post, first in all senses therefore a minimum presentation is required, you have described all other work process. . .
If you say you already use the procedure I described your problem I don't understand.. .
Good morning, I didn't write all the systems that I used until now to not create confusion, but I wrote the most trivial and simple one to explain.
For example if I had to draw a 5000 mm long beam, of which I only care about the two ends, it would also be useful on the model to interrupt the object "exporting" 4500 mm central by closing the two ends.
I would find the drawing ready for the printing table and fit everything in a horizontal a3.
I wonder if you set up a command to do this, because I think I heard about it somewhere.
Thank you very much
In this case I can't help you, never heard of a command like that.
I do not see the usefulness of such a process.
