dandao
Is there an automatic way not to make the fold lines appear in a drawing when I create an open view?
thanks in the meantime x the answer, but in the property of the view I found nothing, while in the standards I do not know where to put handsmaybe in view properties or as admin setting standards
thank you for the answer,specific if you mean:
the line indicating the position of the folding knife,
or the indication of end start fitting of a fold.
in this second case you definitely have to put hands on the standards, or with the command "try" select the specific lines of fold and the gates.
another way, there is the possibility from 3d to export in dxf the development, but you would still get the indication, of the fold points (understood as the line indicating the position of the folding knife).
I'm also curious about what you need to take them off.
