view stairs on cartiglio 1:2.5 - 2:5
  • Thread starter Thread starter foggetty
foggetty
when you set a 1:2.5 or 1:7.5 scale, on the cartiglio you see me respectively 2:5 and 2:15......
mechanically is not very correct; is too much if I ask how to force it to display 1:2.5? ?
Does anyone know how to do that?
use the "search" button will be the solution to your problems, there are many discussions about it! !
I did the research, both before posting and now, but I found nothing about it:
If you have the certainty that it has already been this topic, can you link me to the discussion?
if you use the button, obviously in the inventor forum, and type for example: "drawing scale" comes out different discussions that do to your case, one in particular, started by sincosald, speaks of a problem similar to what you ask; probabibly the solutions indicated are good to you.
However, :http://www.cad3d.it/forum1/showthread.php?t=18321&highlight=scala+disegno&page=2p.s.
If possible write without shortcuts from sms, it doesn't take much more, and it's clearer. . .
Thank you so much! That's what I was looking for.
then you can delete this discussion;)
However if you type the scale in the dedicated box you can also scale 1: 23.4
what you write, he does.
like pine the washing machine.
mode moderator on < < < > > mm off
