surface quality
  • Thread starter Thread starter panormus
Hai esperienza in superfici e stampi?
  • 1 - non ne so nulla
    Votes: 2 9.5%
  • 2 - ne ho sentito parlare, ma non ho mai lavorato con superfici e stampi
    Votes: 7 33.3%
  • 3 - ho una sufficiente competenza di superfici e stampi
    Votes: 8 38.1%
  • 4 - sono un esperto sulla superfici e lavoro per fare stampi
    Votes: 4 19.0%
  • Total voters
    21
  • Poll closed .
Status
Not open for further replies.
panormus
What do you think?
if there is someone who understands surfaces and would like to give me suggestions to do better.. I realize that for aeromodellism can go, but for molds... :rolleyes:
through images it is quite difficult to understand the quality of a sup,
I recommend that you use the controls that it offers: bending analysis, connection analysis between sup. g0/1 etc., curvature and flexion of the construction lines.
the advice I can give you is to simplify the sup. max and to focus on the construction lines ( beautiful lines of surfaces :finger: )
Thank you, can I ask you if you have any tutorials or guides on this?
I've improved geometry a lot. I don't believe it either. It seems well done. from my baby.
to the eye there is still a little singularity in the passage from the "motor compartment" to the area of the lunotto. . .
clear: I am not an areospace: I limit myself to observing the surfaces.. .
I see irregularities in the reflections, both on the steering wheel and on the fuselage, in the tail, before the attachment of the steering wheel. Why don't you place a display with zebra striscies?
catia must have thousand thousand thousand thousand systems of visualization and analysis of the quality of the surfaces and a shade display such as the one you have put is certainly the least suitable.
Of course, I care about the quality of the surface, then maybe for more aviation advice I talk about it with marcof. :smile: that I see to serve as soon as possible, but consider that I have no notion about surface analysis and I am intuited.
Of course, I care about the quality of the surface, then maybe for more aviation advice I talk about it with marcof. :smile: .
there must be a misunderstanding, I am not able to give you advice on how to make beautiful surfaces. I rarely use them.
I've just looked at some "catching" reflexes that you see well
no clear, for the surfaces placed here, for anyone.. for the aeronautical knowledge (not of surfaces) i ask you: is it wrong or with the president you disregard flight and aircraft?
to you the first pictures, tell me if you need different angles or different parameters for correct analysis.
from zebrature it is evident that the surfaces are not beautiful
if you're at the first weapons as an example of modeling is perfect you're very drinkable!! .
As you move on, you'll be more attentive to the curvatures.
Why can't I examine the stabilizer and drift (only sup)?
no, mistakes with the construction curves you cannot expect to have curved surfaces if the curves are not.
It's hard for me to explain it, but you'll know how to do it later.
hello to all
a little aerodynamic surfaces
these are true aerodynamic surfaces that are those in contact with the air, then we notice inside other areas under common for the construction
how to build it requires a lot of surfaces to achieve the final purpose
but to do analysis with zebra strips in which module and which command should you use???? what information can be found? ? ?
hello to all
Since you are very competent, would you also be generous with the community in explaining how aeronautical surfaces should be made (see that my not only wings those mails) and how to analyze them?
Waiting for rs4 lumens I place some image that can help you explain to me, if you can please, how to interpret the goodness of the surface made and where/as possibly I could correct/improvide.
Status
