Hi.if there is someone who understands surfaces and would like to give me suggestions to do better.. I realize that for aeromodellism can go, but for molds...![]()
to the eye there is still a little singularity in the passage from the "motor compartment" to the area of the lunotto. . .I've improved geometry a lot. I don't believe it either. It seems well done. from my baby.
I see irregularities in the reflections, both on the steering wheel and on the fuselage, in the tail, before the attachment of the steering wheel. Why don't you place a display with zebra striscies?I've improved geometry a lot. I don't believe it either. It seems well done. from my baby.
Of course, I care about the quality of the surface, then maybe for more aviation advice I talk about it with marcof. :smile: that I see to serve as soon as possible, but consider that I have no notion about surface analysis and I am intuited.to the eye there is still a little singularity in the passage from the "motor compartment" to the area of the lunotto. . .
clear: I am not an areospace: I limit myself to observing the surfaces.. .
there must be a misunderstanding, I am not able to give you advice on how to make beautiful surfaces. I rarely use them.Of course, I care about the quality of the surface, then maybe for more aviation advice I talk about it with marcof. :smile: .
I like this in a way... but now one step ahead: why and how to remedy?from zebrature it is evident that the surfaces are not beautiful
bybut to do analysis with zebra strips in which module and which command should you use???? what information can be found? ? ?
Since you are very competent, would you also be generous with the community in explaining how aeronautical surfaces should be made (see that my not only wings those mails) and how to analyze them?hello to all
a little aerodynamic surfaces
these are true aerodynamic surfaces that are those in contact with the air, then we notice inside other areas under common for the construction
how to build it requires a lot of surfaces to achieve the final purpose
