arzigogolo
Hello, everyone!
It's been a while since I've been writing in the solidworks forum because I haven't used it for work anymore.
now in the company where I found work they use it and so I found myself to have to replenish it.
after some initial difficulties I have to say that I am taking enough on the method of working of soildworks (coming from inventor) and I am doing my hand, however I am encountering in a problem:
I would simply project the circular edges of some holes between two parts coupled together, but with the "converted entity" tool it does not make me select anything, nor circular edges, nor linear edges.
Therefore, inside the sketch of part n.1, I have to draw circles for each hole (and there are several) using the center of the holes on part n.1.
Imagine that beard if for each hole I have to be there to draw the respective circle and then use the "extruded cut" function.
I thought that with "converted entities" he did as an inventor and projected all the holes in one blow, and instead it does not work!:
It seems strange to me that you can't do it.. And yet I have tried them all.
Do you have any idea how to do this before?
thank you all!:smile:
