Fulvio Romano
certainly there is a misunderstanding only on terms. However, you talk about "work" like energy spent against a potential field, such as gravitational one. if the points are at the same height, the work is null.perhaps there is a misunderstanding in the terms used
I have understood "work" as what I need to go from to b and should be independent from the fate that is done at a speed or another. I mean by work the energy spent to move the body between two points having different potential.
I say instead that the work, which is a force for a shift (see discharging with pierarg) is greater if the force is greater. and since the increase in friction, the force also increases (otherwise the car does not go to the desired speed) , the work will also be greater.
What is the difference between work and mechanical energy? I would say that's the same thing, but if someone explains me, I'm ready to deny this statement, to say that I never wrote it or believed it, and that these words are actually written by an alien who took possession of my account.
ehm... mi iuterest?"the thermodynamic god is always worth, everywhere and anyway! also in a pisci@t@ in the middle of the desert losses are proportional to the square of speeds!" [cit.]
Why? if the losses are x, and then the energy will be x, the power will be x/t.se le losses are proportional to the square of speeds, the power power spending must be proportional to the cube.... Am I wrong?? ?
In fact the spark is in the words of the president. above a certain speed actually (and I had not thought about it) aerodynamic resistance begins to prevail. Let's not talk about viscous friction, let's talk about vortices behind the car that pulls it back. that these go with the cube of speed... I do acknowledge faith, I am very ignorant in aerodynamics. . .
