funzioni e macro
  • Thread starter Thread starter zhzau
zhzau
Hello I have to create a set with two geometrically equal parts but of different sizes, I thought I would use the scale function (as I read on this forum) or at most the macros of http://www.lennyworks.com/solidworks/default.asp?id=20.
Unfortunately, I can do what I'm looking for. I use the 2013 version of solidworks if it can be useful.
the most absurd thing is that the option enter > functions > scale does not exist :confused:
You didn't explain the process you adopted so it becomes difficult to understand why it doesn't work. Besides I have expired the subscription to the crystal ball and the coffee funds can not consult them until after lunch... :rolleyes:
so to feeling I think of these cases:
1) you are looking for the "scale" function in the environment together, where you will never find it because it is the function of the environment part. If you want to scale a part of the axieme you have to right-click on the part to choose the "change part" icon and then the menus will change and you will find "insert/functions/scala/
2) you are using a sp0 truth of 2013 where for some kiss you miss the command in the menus, even if it seems inverosimile; would be more a beta1 version kiss than sp0
Remember that if you want to have the same component both to the real size and scaled you need to make the two configurations of the part so that you can set them separately for each copy of the component you entered.
You're right that the version is the sp0 of 2013, I'll try to look for updates.
I had imagined that it was not applicable in the environment together in fact I was looking for it opening the single part of the project.
cmq as soon as I turn to the version sp1
so confirm that in 2013 sp0 from the menu is missing the command "scala" :eek:
try to see if the icon is available in toolbar customizations, and add it to those.
