aid
  • Thread starter Thread starter alessks
alessks
I would need help on which function to use and especially how,
to draw a kind of outer cam placed on a floor. .
I try to explain myself better and apologize if I'm not very tense in terms. .
I have a cart that must run me perpendicularly on 2 flat guides, so at the 2 ends of this cart I have 2 bearings that act as wheels. .
at a certain interval my cart (basculating) must tilt 30 ° during a "length" of tot. mm..continue maintaining the inclination of 30 ° per tot. mm and then return to altitude 0° during other tot. mm..
So, on the top face of the 2 shoulders where my cart runs..I have to create these 2 cams..the cutter has to follow a certain axis of rotation that I can not understand how to set in solidworks..
I have tried with cutting in sweep and loft but nothing...col loft I can draw the two faces of the hypothetical fried in 2 points to 0° and to 30° but the result is not true..as the loft does not represent me a fresa that moves constantly following a certain axis of rotation. .
You know, I'm gonna have a dwg of one of the two guides in 2d. I hope something is understood and you can help me.
I'm sorry I didn't understand much ehehehe... for what I understand the solution should be the sweep cuthttp://help.solidworks.com/2012/italian/solidworks/sldworks/sweep_overview.htm
