rotation placed at the table in sw
  • Thread starter Thread starter bemu70
bemu70
hi to all I wanted to know if it is possible to turn the view of the table, with the relative views of the drawing, from orrizontal to vertical....I explain:
Most of the drawings I do at work are with the orrizontal cartilage, as we have changed management I have the obligation to save the file in.jpg and no longer in .pdf, but vertically to bind it to the management (doing save as jpeg is printed exactly the viewer...) .premetto that I also have the vertical cartiglio but if I go to replace it with the orrizontal one obviously I would not rotate the views. . .
I hope I've been clear
I don't know if I understand, but don't you first make vertical sheet on the sheet properties?
you can't do it, you should work on the jpg and rotate the image, it's definitely the + fast thing.
for ivan:
ok... but by turning the views remain unchanged, while I need them to rotate 90°
for re_solid:
I imagined... I hoped there was some trick to me unknown, thank you anyway
