pattern of sprocket tooth
cacciatorino
I have a pinion to which I drew a tooth. Now with the "pattern" function I would like to do the others, but I can't do the "group" of the faces, I'm refused both the "open" function and the "tasca" function. how can I do to group the set of faces so that I can then use them to create the pattern?
I actually had already created a simple "group of faces" that includes the faces of the tooth, but then this entity is not recognized by the pattern function... .
I finally solved, creating a pocket for each compartment and then doing the pattern of the three.
that is, it is not possible to create a single pocket that crosses the three toothed crowns.
Hi, I've got the same problem as you. I'm on one crown.
I can't do the "set of faces" command to make the pattern, it doesn't accept any of the four.
in this regard when using the various options?
- Hub
- hub with opening
- Tasting
- opening
difference between "set of faces" and "face groups"?
personally I have never been able to use this tool, since it seems to me that more or less we all have the same problems if who knows how to use it well had pleasure to enlighten us I would be rather happy
- Hub
- hub with opening
- Tasting
- opening
for coat of arms: can you upload the file? I try to see if I can, and in case I make you a video.
I'm home, and I don't have that part. I did that.
thanks for the video but the only steps are sufficient...:finger:
I tried with modeling v17, and I didn't find any difficulty, so I think I didn't understand your problem well.
If you want to put in the pattern also holes, you have to make an opening for each hole I believe. from that which I understood, these commands of grouping do not accept "non contigue" faces.[youtube]gkhfge4dm64[/youtube]
Okay, or try with v.17 and your commands... all right!
I passed to v.18 and selecting the faces differently gave me error "the faces do not form a valid pocket"
I would select with ctrl and not with shift, here's the error ...with crtl you would select one face and go wrong. while with shift everything ok.
for the holes no problem sceglendo "open" however as you say you are forced to select a hole at a time ...
cmq thanks hunter
bye:
