from surface extracted from google earth to coordinates x,y,z with autocad civil 3d
  • Thread starter Thread starter marco73
marco73
Hello, I am new to the forum and I ask you help with the following problem.
con civil 3d 2010 I erred a surface from google earth.
I need to extract the coordinates of the points of this surface in x, y, z format to have a dtm of the soil.
can I use directly -extend by selecting the surface obtained or recommend another method?
Thanks for the answer.
can I use directly -extend by selecting the surface obtained or recommend another method? .
Do you want to be a rhetorical question or what? Have you tried to use extinguished on a surface of civilization 3d?
is not a rhetorical question: I have little experience of civil 3d. know a method to extract from the dye surface generated in civil 3d by google eath the cloud of points and its coordinates x, y, z to it relative?
Yes, the surface didn't import it, but I created it from google hearth with civil 3d.
Yes, okay, we are saying the same thing...because you have the surface assigns to this one style where only the points are visible then with the command extract objects (or possibly the explosion of the same) turn the points of the surface into acadpoints. At this point with the excreted command you create the ascii xyz file
