Liquirizia28
Hey, guys, I'm studying to take the machine construction test. I would have questions to ask you.
(1) study life fatigueIn case I find myself having to check the fatigue life of a tree on which elements such as dense wheels are cast, how do I face the study? My problem arises once you find all the tensions, various diagrams of moments and cut, etc. what I don't understand is like a voltage coming from one or more dense wheels, this can have an average or alternating component.
If for example you have variable loads over time within a maximum and a minimum, clearly the alternating component and the average are calculated. but in cases where there are no variable loads like a transmission through dense wheels as I address the thing? Moreover if you want to apply the relationships on the fatigue study (as goodman) I need both components.
I was thinking now that since the load is constant, there is no alternating component but only an average component.
In this case, for example, goodman's relationship would be simplified to:
average sigma = breaking sigma / safety coefficient
but then how can I establish the number of cycles endured by the tree? It's just a rupture check!
(2) studio bullonatureI have to study a bolted joint with 6 screws (note: m12, 8.8) and understand what is the maximum torque moment applicable to the joint, considering also the elasticity of the flange and a known external axial load (ne). I did not understand if this time required is equal to the moment of tightening the screw itself!
I for now have confined myself to the study of tensions between vine and flange using the triangular diagram, where I placed as known the precarious ns (given from the tables following m12, 8.8) and the axial outer load in it. found the increment that occurs on the vine, I added to this also the precarious ns and in the end I found the total axial load on the vine.
at this point the moment of tightening is found with the formula:
clamping time = 0.2 * ns(total) * d(vine diameter)
Sorry about the stupidity of questions...and thank you in advance:finger:
