carry lines and blocks on the same floor with autocad lt
  • Thread starter Thread starter IN.TEC
IN.TEC
Hello, everyone!
Saturday morning problem. . .
I have a series of carpentry drawings, made with a special program, in which the lines are not all "spalmed in the plant", to understand with " z to 0", but rather drawn in space, in fact turning the view of the design instead of seeing a "unique line" I see various levels of design.
now the lines with the properties I brought it all with " z to 0" but how can I do with the blcchi, since the design is full, without exploding them to bring everything to "z=0"
Is there any variables? ? ?
Even if I've been explaining shit, I hope you understand my problem. .
thanks and hello
Faithful
if you have the installed expresstools put in view _top and type flatten, the door procedure everything at zero altitude, then also lines, without changing them from the property window.
i.e. that the blocks treated with this command are renamed "singolarly" with suffix *-flat-1, *-flat-2, etc.
Unfortunately I cannot do as you suggested, because now as I do not use my autocad, but I am in an office to do a collaboration and I do not have a full autocad but a lt....
can there be other solutions? ? ?
p.s.
I don't care if the files are renamed, just don't explode them.... .
Faithful
ad a pulsante questa macro:
^c^c_ucs;;_select \_move _p;;0,0,1e99;;_move _p;;0,0,-1e99;;
Sourcethat the objects of the blocks, if exploded, would seem to return to their position of origin.
thanks gp!!!!
It works great, only remains some text (which are actually blocks because exported from another program) with the z to strange values, but I don't care much.. .
...and at least now I can work with the grip!!!! !
Thanks again
Good morning to all,
trying to solve the same problem as the balls I came across in this forum. I created the button with the macro above; seems to work but then I no longer see the design in the model, from any point of view. I keep seeing it instead in the layout. Did I do something wrong?
Thank you very much.
serene
Yes, all three things.
I didn't say it was the first time I tried to create a button and that until two days ago I had never heard of macro. It's possible that I did something wrong... I created the button and copied this: ^c^c_ucs;_select \_move _p;;0,0,1e99;_move _p;0,0,-1e99;; nothing else...just?
I checked.
you actually the problem was just that. the new button works fine.
Thank you so much! a very useful comenado!
