problem loss of entity after error
  • Thread starter Thread starter turion86
turion86
Hi guys I have a problem with a 3d design in practice I made a 3d kitchen all right I saved and now I have a surprise.
half a drawing is missing.
I had a mistake before, and even with the recovery, the same half of the drawing was erased, I remade it and saved it without problems, but then today when I reopened it half a design had disappeared as I can do?
Thank you very much
sorry so much the delay..cmq thank you so much for the link however I solved by making a previous version restore by clicking right on the file itself.
Listen, I wanted to ask you something, that problem happened last night when I finished working on my design, I saved everything, and I went out, nothing had crashed. I'm going to open the file tonight and I missed an item.
I press my pc has only 4gb of rams it's not really bad but I've already found graphical errors only that it's been a while before giving me graphics errors now erases my objects.
Can I ask you a question?
but it's not that since the layers were not saved by a specific name autocad does, like, a kind of cleaning (purge) and erases them?
It seems really strange to me like tonight I opened the design and objects that I had moved yesterday I find them again where they were before yet I saved listen but it will be because when we zummo gives me a mistake like modeling error. . .
Anyway, I think it's a matter of graphics. .
What do you think?
working in assonometry often happens, if you do not use with shortness osnap and ucs, to place objects in space at random points. I recommend that you check, periodically and before closing the design, if the project remains correct even by changing assonometric view or displaying it from top or side.
some, to have immediate control, are accustomed to drawing with windows flanked with plant, prospectus and assonometric view.
If when you zoom in, there's really a problem. try uninstalling and reinstalling. also check to have at least the minimum hardware requirements to turn the application. I can't tell you anything else.
So I downloaded the file, but when I go to install it, it says the autocad version is already updated.
guys like I have to do when I change view or try to zoom under the command bar is written "type of unknown surface in the silhouettes
error modeling operation"
I tried to download the server pack but it tells me that my version of autocad is already updated this afternoon I get ram slots and we will see if the situation improves currently in all I have 4 gb ram you think you increase it up to 8gb. Okay?
In any case, I've noticed that when I do vision change or zoom, it's really gonna take a little bit. I hope to solve
I wanted to do it, but how do I know for sure it's a radeon ati but I don't know the model how I can see it?
I deduce that you have installed generic drivers and not specific drivers of the ati.
you see them in windows properties.
the radeon drivers of the ati then go for "series".
ever heard of the control panel?
Guys... it's okay, but this isn't a basic computer forum. make yourself a corset or read a manual; This is the base!!
