ogni step un catia
stef_design
hi guys, this is the solitude:
- I'm open.
- I open a step to explore resources
- another cat opens
every step file that opens a cat.
How can I do that?
I would take them by mouse selecting the files and drag them into the cat ................ not use step but usually works with any program installed on windows :)
excuse but the step attachment you must save it before opening von cv5. if you do it by opening it directly from outlook you haveadviato cv5 without your settings then unusable environment
hi, I know that so they open but when they are on outlook if I open the step directly from the mail opens me a new catia.
I think it's something on the registry.
windows: if you provoke him, he reacts.
stef, but don't treat the steps like the tender power point with kittens sending you every friend. follow the falonef directives.
save on disk and open it from catia.
If you send this question to the caia support, I think you feel like answering: "open from outlook and windows does what you want? What do you want from me? "
Okay, you're right. I'll explain the whole situation.
If I have steps on a folder, I've already started, I double-click on one step another cat opens.
I also know that the best situation is to drag or open the steps from catia, but as this behavior happens only in a computer I wondered why.
If you notice, when you open a step or iges from a folder, catia opens it in the current session.
instead in this ws, catia opens another catia.
I liked to solve the problem.
is it not that the incriminated pc is the one where you are also trying to install + cat?? ? ? ?
I'll explain... but maybe you already know...
if you have v5r20 and use x work , but install to try v5r21 if you doubleclick from windows on a file opens with v5r21 (so other session) even if you opened the v5r20 , it is opened with the last cat installed .
but maybe it's not your case ....... .
No, this is another... that of my boss:
Yes, yes, I know this happens to me on my pc because I have r19 and r20. when I open a step with r20.
Bye-bye.
...... Who knows that they are always the pcs of the messed up garments, full of viruses, nailed, with 2000 icons on the desktop, and not even one that is relevant to work........................ Why don't they use it to work???? :): thought ot.
hello to everyone, I'll put the solution to the problem.
you have to go to the registry and delete the 'open' item on stp_auto_file
This way, when you try to open a step, win asks for the program.
just choose caia and the game is done.
thank you all!!! you are always mythical!
but practically what would it do? ? ? ?
xthat I believe that what you did you did also did from "folder options ", you went to the step file and said to open it with cat or with what you wanted or remove the default file, which should ask you with what program to open the file.......... .
but your problem was that by double-clicking on a step file you opened a new caty and so x any clikkavi step file................. each clik a new catia.
Am I wrong??? ........... maybe I misunderstood:redface:
