ECCLETO
It's my first post, so I apologize for any mistakes.
work in a company that makes suction plants and inside is still used a 2d software called gbg (of cadlab) that does not exist practically any more on the market. by self-taught I "converted" to the autocad and normally use the 2006 version.
I would like to make a leap forward and start working on the 3d but I am browsing with thick fog regarding which software to use.
Since from the forum I see that different of you have a lot of experience on piping, I would like to ask you a tip.
our plants are rather simple (it is not a true piping type gas/oleoducts, at most there are 4-5 lines of pipes with diameters ranging from d.200 to d. 1000 ca) but I would like to create a library with my 20/30 diameters of galvanized tubes that are usually used, curves, branches, hoppers, joint clamps, etc.)
would be fantastic then implement in 3d also other components such as silos, sleeve filters, fans etc.
then the maximum could be to have a list of materials (mt of tube d.xxx, n° of curves d.yyy etc.)
I have recently seen the mep 2012 but it gives me the idea that it is not the suitable software being generic for planters of all kinds (electrical, hydraulic and conditioning plants)
I realize that our sector is a niche, but I suppose I'm not the only one who dreams of software like I mean it, indeed it probably exists and someone here in the forum maybe already talked about it.
What would you recommend?
I thank you in advance for the attention and take the opportunity to greet all the participants of the forum.
Mauritius
Mauritius
