link catalogues thinkparts and smart objects
  • Thread starter Thread starter Eritro
Eritro
Good day to all
I recently had to re-start everything (think3) on new pc and I don't know where to go to search the thinkparts, while first I had them!
I hope someone will give me directions on how to show up in the thinkparts catalog at least something. . .
Thank you for your attention
for thinkparts, if you don't use thinkteam, you just need to reinstall the catalohgi.
tools->thinkparts->libreriacatalogue
opens a window -> right-click import catalogs. .
...\thinkparts import
for smart object you find them under ...\thinkdesign\so_libraries and you have to set the path under tools->propieta' as here
smObjPath.webpIn any case, in the online guide you should find out all this information better explained :)
soon
Matteo
View attachment 32905In any case, in the online guide you should find out all this information better explained :)
soon
Matteo
and if you use thinkteam how do you import catalogs?
Thank you very much for the answer
you should relocate the centralized configuration of tteam, not reimport catalogs, because they are already present in the database.
But it must be analyzed calmly before proceeding. .
I recommend you to contact think3 customer service or feel a consultant who understands some of the technology ..
soon,
Matteo
Hello everyone in need of help, I am trying to make a pot using the spindle surface, but I was stuck cause error "the thorns is not perpendicular to the edge". I don't know how to do this!
You should open another discussion .. here you are out of theme ..
spindle surfaces want the two curves to be perpendicular to each other..
in practice the beginning of the thorns must be perpendicular to the starting curve .. if it is not angry ..
Anyway to make a pot there are endless other possibilities... try to indicate the shape you want to get..
Matteo
Hello.
Would you please tell me how to do to have a product demo of the license time bombed or similar type?
the references I had in t3 enpa, mapi there are no more ... or maybe there is no more t3?
Hello antonio,
we met in t3 a few months before you left .. I was doing an internship then for the pso ..
t3 is still there, and some of your colleagues are still there .. elbe,semi,clay ... shortly will be out 2015 with a new engine for positioning and some improvements for the interface ..
If you're interested in a demo, we feel privately.
soon
Matteo
