save with previous versions a 2d file
  • Thread starter Thread starter otrebor81
otrebor81
I would like to know if it is possible to save a 2d file in a pre-censing solidedge version.
in practice I have st3 a my client on 2d v20, without passing by dxf there is way to save a native file in previous version?
already discussed many times... no, it is not possible to save in previous versions, either 3d models or 2d tables.
the only solution is in neutral interchange, step or parasolid files for 3d models, and dwg/dxf or pdf for 2d tables
no it is not possible, even because in st3 there are "objects" that in v20 there are not and others have been modified and the v20 would not know how to interpret them.
neppure esplodendo the viste?
no, it is not a matter of views is a matter of objects.
for example from v20 to st3 the tables have changed to have an infinity of options in more than v20 that the same would not know how to interpret.
You had to explode everything that's like a dxf or dwg.
