retino problem at different levels of detail
  • Thread starter Thread starter kamikaze
kamikaze
I have the following problem, at the low level of detail I can manage the level of detail, there is in fact the possibility to change it in type modification.
but if I choose, for example, a medium level of detail, I can't find a system for, for example, sampling walls with a black solid net.
and also with regard to doors and windows there is no way to make visible the senses of low detail?
Thank you very much
go to replace visibility/graphics and for the walls imposed the low detail level instead of "from view"
for doors and windows you can do as above (for walls) or edit families so as to make the openings visible even in low detail
to tristan I wanted to say that he deprived me of the emotion of being for the first time on the part of "what he knows" and that he answers to the posts of others....ahahahahahaha;) obviously now I would not allow me to add anything else.
thank you so much was really helpful, I have not understood all the commands present in substitution visibility/graphics, but with a little bit of dismantling and attempts I will manage to dexter me. in the meantime really thank you because I managed to fix the problems I had.
you are really the best
