hose liner
  • Thread starter Thread starter yug91
yug91
Hello everyone... .
I have a big problem I have to make a project where I will insert the mechanized ventilation only that I can not represent the pipelines as I want! the pipelines are all flexible tubes so I tried as first to make a zig zag line but I did not like it for the lines tips, then I tried with the isolation line but it is not good when you make direction changes and then sincerely only if very small can seem to a conduct. So I tried to create a line but I didn't know why but after I lost 5 hours I couldn't. condotta.webpI don't know if I can see the photo that I've inserted I'd like the line to be done so or simply that the two outside parts or even with the inner lines! Please help me if there is any good soul that can create lines can help me!
I don't have much time
I'm sorry, but I can't help you. Maybe you can create a proper length block and then you fill it as many times as it takes. It won't be the best, but it works.
to that is the method "brutal" I wanted to create a line that so was all more immediate!
thanks in every way:finger:
I wait for a small autocad genius:cool:
