no commission at the table? ?
  • Thread starter Thread starter bich
erm... another problem: I did as they said stefanobruno and peppe, but another problem has arisen... if I have a set and untouched all the parts that make it, on the cartiglio I find all the exact quantities.... if instead I go to unto the axieme, I find myself with the box of empty quantities! :mad:
to me instead happens the reverse thing, in the separate of the asses no problem, while the tables of the individual pieces do not leave me the correct quantities.
bradipo, tell me step by step what you did, so let's see where the hippo is!
I did so: I created an ipt and iam template with a custom "quantity" property. then I opened the idw template and I inserted the newly created property into the cartiglio. when I have to fly, I open the axieme, from distinct components, select the column quantity (default) and copy it in the column "quantity" I created. That's all. when I go to fly the individual parts, the quantities come out correct. when the set that composes all parts unfolds, the box "quantity" in the cartile remains empty. . .
if you have put the custom property in cartiglio it is normal that it remains empty as it is "weighted" by the custom property that you definitely do not have in the file of assembly (.iam) of the total.
for the overall there are the tables list parts that you need to ball the asses and here then you will have to put the amount property of each part that you want to leave that of inventor.
hi ilario, si per la pallinatura ok for the rest I updated the template together with the custom property (I had escaped..). while before in the cartiglio together the quantity box was empty... now I have updated templates and together, and a nice "0" comes out! ...
