print multiple sheets on the same dwg automatically
  • Thread starter Thread starter enry86cami
enry86cami
I tell you my problem:
I use autocad 2013 and in a single sheet I find myself always minimum 20 carts with electrical schematics.
to print each sheet I have every time go to print, window and ok...
practically to print a sheet I must always select its contours. . .
It's really pale. . .
Is there a way to get autocad to understand that he has to consider a cartilage as a sheet and give an automatic print?
....use autocad 2013 and in a single sheet I find myself always minimum 20 carts with electrical schematics. . .
speak of sheets and in each of these at least 20 cards... but use the layouts?
or you have to learn how to use them better, or if you don't use them you have to use them.
in a dwg I have to examples 20 files and so I would like to print 20 pages... .
I don't use the layout...
Of course. using the layout!!
the usual question: "I run a bitch. Is there a way to get on the highway at 130 km/h? I don't know how to change the marches"
the answer can be one: learn to use the change!!!
Perfect! I will try to learn how to use the gearbox:wink:
I saw a video on youtube explaining how to create a layout and print on scale 1:1 in a4.
However in a layout has only one sheet. . .
You explained very well, also because there is little to understand. no need to attach files...and the answer is always the same
