change a drawing via a connected electronic sheet
  • Thread starter Thread starter saro
saro
Hi, I have a problem with a file:
After extracting the data of the attributes blocks of my design I insert the electronic sheet directly into the model. My question is:
is it possible to change the data directly in the electronic sheet so that the data of the attributes blocks change, why connected to the electronic sheet?
example:
I have 50 doors with width-height-type door-n° floor- etc.
If I have to change the width of all doors it can be complicated to go search in the model every single attribute block and then enter it and change the data. in an electronic sheet everything becomes easier...... if it is connected to the design model.... .
