OmarT
Good morning to all,
I have a little problem.
I create an extruded parallelepid. I eliminate the upper face. I create a contour surface with shaped pockets inside using the contour of imported surfaces.
when I merge the surfaces I have a solid again.
But when I want to create a sketch on the upper face, this is as if it did not exist. She won't let me select it.
Do you have any advice?
omar t.
omar t.
