Rafael90
Greetings to all students and engineers of this siteI am a mechanical engineering student at the first sockets with design. I was assigned the task of dimensionalizing the whole transmission group of a classic lawnmower (to understand us like that of the enclosed photo). the transmission is very simple: the belt takes power from the motor shaft (the same connected to the blade) and moves it to a pulley that rotates a couple of conical gears that in turn put a gear in place. but the problem does not concern the structure of the transmission nor its dimensioning. the problem is that I have to design the gear so that it has three gears, that at each gear corresponds a certain constant speed. My problem is the following: when the speed of the lawnmower increases also the power that the transmission group absorbs, but the engine cannot be accelerated or I know a way to get to the belt a greater power depending on what is required. How can I solve this problem (as long as it's a problem and not my horny gaffe)?
I hope I have been clear enough in the explanation
