flange contour length "up to"
  • Thread starter Thread starter Tarkus
Tarkus
as from title,
sheet metal environment:
I sketch a profile, then command "flangia contour".
the width of the profile you create I can determine only with numerical value.
the voice "width extensions" is not sectable and is fixed on "distance".
I would like to use the classic "up to", maybe up to a plan.
igo image for clarity
Is that possible?
How to do that?
as from title,
Is that possible?
How to do that?
hi tarkus, I tried them all and the option "width extensions" is never selectable by staying fixed on "distance".
I read the guide online, and it seems to have understood that this option is not activable during the creation of the flange, but it becomes if you create a flange contour on an existing geometry, for example on a edge of a sheet metal part.
Then it activates and allows you to specify the "width" of your flange with the options "up to" and the others, but it refers to the width, that is if you decide not to extend it throughout the line/board of the object you selected, not to the length.
Then I don't know if I get it right.
thanks arzigogolo,
I see you've lost time, too, and I confirm my impression:
No, no, no.
sin, another lack...
