recognition sheet metal
  • Thread starter Thread starter xxfast
xxfast
Hello, everyone.
I created a sheet metal part with sw, now I brought it to catia v5 r19 , but I can't convert the part to sheet metal through recognition.
Is there someone who kindly enlightens me?
having performed the piaca with a feature loft the recognition of the features is partial and however from errors to the reconstruction of the fold.
But through the surface developer you can still get to the result.
Thank you so much.
I have a lot of help, since I'm in the first arms with catia.
If I didn't get it wrong, you first created a surface and then from the sheet module, you got a superficial hopper.
Could you tell me something about the union command?
I know him very little.
:finger:
more than created, I extracted the surface of your model, after which I created the thick sheet, given the two side folds are not derived from a radius, but you created a multi-section, so the system fails to determine the curvature.
the command "union" sere essentially to join two or more pachs of surfaces that have 1 edge in common.
in your specific are the pachs are the internal surfaces of the sheet that I extracted with the command "extreme".
I'm so sorry, another thing...
I would now like to export the dxf of sheet development, but I can't.
What can I do?
it says creation failed.. .
Try to start drafting, select open view, select a 3d wall and create the open view of the piece, then save as dxf selections.
to me if I try with the dxf button in the sheet metal module saves the file, but first it tells me that there is a feature that is not of sheet metal and that then the dxf could not be corrected.
use v5 r20
use v5 r20
I r19.
Anyway, you're right, I didn't think about it.
It was enough to use the drafting module, the only flaw that does not put the fold lines, but does nothing. :finger:
for fold axes simply activate the "axis" option in the panel of the properties of the developed view.
