reduction of quota symbols
  • Thread starter Thread starter CAROLINA
CAROLINA
I kindly wanted to know how I can reduce the section symbol in the plant because I have to print at 200 and they are very large.
Also in plant quotas the "extreme mark thickness is strengthened" and has a line thickness of 5, but it is not editable in the properties of the project browser.
I hope I've explained thanks
carolina
hello carolina, the section symbol is a loadable family; to reduce or change it you should actually edit the family
select the quota and from the palette of properties click on "change type". at that point you should find a "thickness of the line of the mark" parameter; I'll change it from there
