Piron88
Good morning, everyone.
I discovered hot water with this software I just found out about. But my first approach was not the best.
I tried to open (and also import ) a dwg file with inside the layouts. at the end of the wizard for opening the file (or import ) tells me "filename" is invalid and cannot be opened.
I tried to open it from both layout, viewport and model but it gives me the same error.
for the moment I solved working on dwf but I would like to be able to work on dwg.
Can anyone give me a tip?
