area of scale
  • Thread starter Thread starter IN.TEC
IN.TEC
Good morning, everyone.
I wanted to ask you for help with creating a window (scale area) in paper space.
when I try to create it gives me the message "the window can only be created in the model space" (translation made by me by a mechanic in English). in the model space I create it without problems.
I ask you help because this only makes it with drawings starting from templates of a customer in particular, with others there is no problem.
Can you tell me if there's a variable you can change to solve the problem?
Good job
Faithful
window (amscarea) works solo in model space.
from the online guide:a scale area is a rectangular area in the model space that has a different scale from the model space scale. You can set a scale area to automatically create a view in a layout using a window.
ops... not having activated the command description I hadn't seen. .
Okay, thanks for the massivonweizein answer!
but the question arises spontaneously at this point... What command did I use until today? and why in certain designs does the command work in the layout?
after so many years of use I'm still amazed I'm planning... :eek:
in model space is used amscarea
in paper space use mview
It can't be vice versa!
quoto, although the button (window/area with scale) used is always the same in both "paper space" and "model space" changes the command that is launched.
in fact in "paper space" opens the window "view" while in "model space" opens the window "area with scale".
enigma
