obyoba76
hello to everyone, I write here because my topic is about beam systems. I tried to clarify my doubts looking in the forum, but actually at the moment I just increased them. I would like to know if the procedure I am using to make a roof is fine or if there are better methods. to create the beams I used the beam system command, to cut the beams in correspondence of the skylights I used the split command. One thing I can't do is where I split the beam and then I erased a part of it, I'd like to remove the contour to the beam where I don't need it. then another question is this: once you set the entirety to the beams, if later you decide to change it, you have to do everything again or is it possible? I tried to select them but I can no longer see in the property curtain the "riga" in which I had inserted interasses 1m, to change it in automatoco to all. I hope I'm explained. Thank you.
