change of a set
  • Thread starter Thread starter Michelefi
Michelefi
modifica solido di base.webphi to all, I have a problem, I would like to simplify a constructive that they sent me because I do not care to have all those details, the problem is that when I open the aid and I want to change a part, I open a dialog box in which you ask me to change the "basic solid".. but I would like to change the "works", like to remove some sunshades or to change or delete some fittings..
those parts that you see with the word "base", or are not made with inventor or otherwise do not have the tree of the work.
So if you want to simplify the part, you have to complicate life a lot: you need to fill asole and bevels with ad hoc extrusions.
I don't know how much it's worth.
So you're saying I'm going to remodel it all? Is it possible that there are no other ways to solve the problem?? :mad:
- - - updated - - - -
solid imported by other modelers?
Yes by other modelers
- - - updated - - - -Yes by other modelers
creates a simplified level of detail where you will close all holes....
