kitelakes
Hello everyone,
I have encapsulated, and I would like to use revit as the only cad program, not to yield to the temptation to export the table in two-dimensional on autocad and to work there.
in modeling, for now, I have no particular problems, but I find "too hard" the layout and printing of the boards, unless it is wrong.
1
I'm doing a project of overlay.
I produce the existing table, and amount the views of the plants, prospects, sections.
If then I have to make table passage and table project, do I have to duplicate all the views again?
This is the only way I understand, with the result that for each plant/prospect/section I have 3/4 views.(In the sections overlap the label in the cutting line by making confusion)
is not possible duplicate the table with views and then change in each state?(actually,project,comparative)?
Second hand
I have a staircase that is partly covered by the upper floor.
when I insert the labels, I disappear the floor and it shows me the part of scale below .how to do to eliminate the part under the floor?
3rd question
the characters of the labels (local, area-volume) are too small, I can't find any way to enlarge them, and believe me I tried and also text, anathet, can you tell me something?
thank you very much to all and in particular to gfrank that I see very helpful on the forum..
1
Second hand
3rd question
