multiple modification of blocks
  • Thread starter Thread starter baobab123
baobab123
hello to all you can change through the block editor, with the iron command, a set of blocks without having to add to each block the possibility of ironing it?
or even can give different blocks the changes made to one block making it dynamic!
I don't understand what you mean, though if you mean the change of a block extended to a set of blocks inserted in the design... all blocks must have the same name, otherwise you have to change them one by one.
