projection walls with different thickness
  • Thread starter Thread starter mario cant
mario cant
I have the problem or the particular need.
Suppose we have a planimetric section in which there are balconies whose parapets are 0.95 cm tall. while the cutting plan is set by default to 1.20 m.
it follows that the parapets are projected and not dissected
in the press of the said planimetria you want the parapetti have a different thickness both the projected and the dissected, so that they disinquire.
How can this be implemented? ? considering that in styles > pattern object board there is only one “type” of wall!!!!
Another possibility is to use a filter set to a parameter (e.g. marking) and redefine the graphics of the filtered elements.
so you get the chance to apply it several times.
I like your :wink more:
Thank you. both of us..
line setting I understood it easily ....the process passes creating preliminarly a style of line ....I also managed to put it into practice.
As regards the procedure described by lances, it is less clear to me being a procedure more by experts!lance Would you mind giving more details?
hello, for creating a filter you can see this post, if you have created a type of wall specific for your parapets you can filter for example by family, as alternatively as suggested lances, select all the parapets in the sight and in their instance properties in the marked field, insert a word that allows you to distinguish them from the other walls in the sight.
