multipage function on autocad 2013
vaxgelli
Hello, everyone.
I on autocad usually work on documents of many pages (from a minimum of 40/50 to reach even 1000 pages).
Current use autocad 2004, for which I created functions that allow me to manage a single file within which all the pages of my document are contained.
within the file I use a layer for each page of my document (layer 0001 for page 1, layer 0002 per page 2..... layer 0342 for page 342 and so on) so that I can move quickly inside the document and make changes quickly. in fact I have created functions to move back and forth in the pages, to go up to a certain page, to copy/modify the common today on multiple pages and so on.
all these functions on autocad 2004 I had defined them with the "defun" command (define function) within the file acad.mnl.
now in the company are finally updating all licenses to autocad 2013. the problem is that I can't report the functions I used on autocad 2004 also on 2013.
So I wanted to know if there is a possibility to define functions also on autocad 2013 so that we can continue working as I do now.
Alternatively, I was interested in whether there is a possibility to manage multi-page/multifolk files on autocad 2013 or if someone has implemented such a function.
thanks for the attention.
tree
I don't know if I understand your request well but try to document the "sheetsets" of autocad
I didn't understand your question very well....
why don't your functions cover them from the acad.mnl file inside an acaddoc.lsp file??? did you create menu macros?
regarding your second question "alternatively, I was interested in whether there is a possibility to manage multipage/multifoil files on autocad 2013 or if someone has implemented such a function. " in a few days on my site you will be able to try the 'table' software that maybe could do to your case
Hello Dominican.
I am totally unaware of how autocad works 2013, so I didn't know where to place my functions..... I saw that there was no more the acad.mnl file but I didn't know where I could insert those functions.
Now I make a try, alternatively I will take a look at your website!
I briefly explain the functions that I have created and that I use:
As mentioned, I have appointed the layers progressively.
the functions created are these:
+ command: I go on the pages (if I am on page 30, I turn on layer 31 and turn off layer 30)
command -: I go back to the pages (if I am on page 30, I turn on layer 29 and turn off layer 30)
fx command: I go to the x page (if I am on page 30, I turn on the x layer and turn off layer 30)
fcopy command: copy the items selected from the page where I am in another page of the document
command fserie: copy the items selected from the page in which they are in a range of pages (if I have a circle on page 30 I can copy it automatically and in a moment on pages 40 to 300 volndo)
soon
tree
