marcofa
I am designing a variable step propeller system for a small drone of 2.5m wingspan and motor 50cc with 8000 rpm.
as a propeller three blades found in the modeling field from 26" step 10" that weigh each 64 grams.
because I am not an aircraft designer, in the calculation of the resistance of the carrier hub I have come across a calculation problem that leads me to unexpected results and to intuition abnorms.
due to the centrifugal force/centripeta the single shovel rotating to 8000 rpm will be prompted to traction in its attack to the hub, and in the case of failure of the bond it would leave for the tangent doing damage.
and here comes my doubt in the calculation of the force applied to the shovel.
shovel weight 64 grams with baricentro to 160 mm from the axis
rotation 8000 rpm
I get a force of about 7000n per shovel, that is, the hub will be urged by three forces at 120° each of 7000n.
Is it a correct calculation or I've lost a factor of 10 on the street? I think for a weight of 64 grams a result of 7000n is abnormal.
if someone let me out of the swamp will have my eternal gratitude
rotation 8000 rpm
