marcof
imho (and not only) complex profiles within a single sketch so that they are referenced to più feature diverse you should use with extreme parsimony. sharing the same sketch for multiple features is a different matter and independent from the complexity of the sketch.calm calm .. if you have certain complex profiles
or if the sketch is shared in + processing (so by force of things is + complex
in comparison to a profile for a single processing ..) then can make sense starting from dwg credible ..
importing complex profiles from autocad as such for, for example, the extrusion of a particular figure and already elaborated from the first feature can be the exception that, according to me, confirms the rule.
the substantial difference is that the representation that was made in 2d of a 3d object has little to do with the set of sketches necessary to create the same model on a cad3d and I repeat: in the traditional 2d the amount of geometry to draw is infinitely higher than what it serves to start in 3d with the first feature of extrusion to which the others will follow, all based on simple sketches.
even just thinking of using the three classic 2d views as a general layout to command a part in 3d seems simply absurd. a parametric cad allows less freedom of change than a contextual so we only lack to bind the whole story of the model to the sketch of the first feature. So much worth returning to the 2d...
