extrude a sketch projected on a face
  • Thread starter Thread starter killer0007
killer0007
Hello, everyone.
after creating a solid semi-cylinder, I created a tangent plan and drew them a helix.After doing this I created a 3d sketch to project the helix into the solid.
the point is that now I would like to extrude the projected helix but I can't, in 3d sketches it doesn't let me extrude.
I leave the file to better understand.
I'm using inventor 2013.
Hello, everyone.
You know I don't understand why you want to extrude the 3d sketch?
Maybe, since you're in a sheet metal environment, you want to use the sketch for a cutting operation?
Why don't you extrude the ellipse you drew on the tangent plane? (and then maybe cut the solid part you don't need)
I think it's not necessary to project the ellipse on the surface, but once I do the sketch on the tangent plane, you can try using the "swimming" command.
Just like you say.
now I try with the command "balzo" (if I find it).
In the meantime I had solved before creating the flat sheet, then cutting the helix dopidid that I used the command "full part".
Thank you so much, it was the command I was looking for.
