I take this thread back because I would like clarification if possible.2 roads:
do the piece in sheet metal environment, then:
- command "explain"
- scrapping and cutting of windows
- command "fill"
- Flat model
here is easier:I take this thread back because I would like clarification if possible.
how do I realize in sheet metal environment the piece of the first image (without holes/opens), then can I explain it?
Okay, I think I get it. only the sketch of the profile already curved, without creating the "face" but directly the "flangia contour".simply draw a sketch with your profile, then use the command "flangia contour".
changes a lot if I leave the default value?as it is a piece of shit, remember to set the factor k=0.5
depends on how much you set the k value.Okay, I think I get it. only the sketch of the profile already curved, without creating the "face" but directly the "flangia contour".
I just know the sheet metal environment, and I ignore almost everything (I'm reading the old threads).
