Reynolds vs. Grashof
I see that you share what we are thinking of our professor who has assigned us an indispensable job, that we had intuited was made with cnc machines, and that instead we are forced to adapt to the use to traditional machines given the few skills that we have been provided and only on processing of turning, milling and drilling.
Since we are required, in writing the final report of this project, to provide all the parameters of the processing we perform and since those manuals from what you say do not have standard working parameters obtained through formulas but only related to the skill and experience of the operator, we are ahead of a crossroads:
1-eliminating all concavity processing, however, leaving the milling of the inner part of the feet (where the coupling with the impeller occurs) and the central foil that being straight profiles can be studied with the method taught (ah I forgot the holes)
2-leave concavity processing by narrowing it to a single grinding and polishing done manually without being able to assign any parameter and justifying this choice based on the experience you provide
