GianniM
I have this doubt that, maybe you know how to answer.
I would like to create a set to manage the grilled panels with inventor. A grill is like this!
I would like the axieme that I go to create to be able to change the number of plates and swallows inside it according to the maximum encumbrance, but maintaining a predetermined interasse. any differences should be compensated at the ends.
therefore if I have a grilled 18 cm wide and the swallows are at 6 cm should appear 2 swallows with distance from the edges of 3 cm. In this way every time I have to place a grill would just indicate the maximum size.
Can you do that?
Can you do that?
