material problem : all too shiny
  • Thread starter Thread starter Petrinho
Petrinho
Hello, everyone! !
I'm at first with autodesk inventor and I have a problem with the assignment of materials, I'll explain:
any material assigned to a piece (material and appearance) this always looks shiny and reflective. . The wood is reflective! ! !
I press that I have not changed the settings, I place now two pieces...one is the original piece that I downloaded from the internet (which as you will see will result aluminum satin) that is the result I would like to get, the other is the piece made by me, practically identical to the original except that it is shiny and reflecting! !
the display style (two lights ) the material (aluminum 6061 ) and the appearance (spoke ) are identical for both...but why is my not realistic as the original piece?!? ! ? !
If the appearance, reflexion and shadow is equal in both components, it would seem that in the first image the textures are disabled while in the second there are
Unfortunately the problem is not the textures.. .
I ask vein but personally I don't know how to give you other suggestions, I haven't even approached the 2015 version and I haven't even looked at what they have modified on style management, which I said frankly, I have practically always ignored even on previous versions.... when I have to prepare models to show customers or pass them fast on showcases or if you need more decent stuff I use other programs
